Hi,
I'm currently replaying Skyrim on legendary difficulty and I'm at level 10 but I've noticed enemies almost always attack my companion first. I don't remember it being like this last time I played this on default difficulty but then again I don't remember if I had a companion most of the time.
I definitely need a companion this time round though as it's ridiculously difficult without her as it makes the game for want of a better word..."awkward". As in I could be employing cheap tactics like using the terrain to my advantage whereby I can hit the enemy but the enemy can't hit me or one hit then leg it and then rinse repeat after healing.
The quest I've just done whereby I had to fetch the Fragment of Wuuthrad from Dustman's Cairn was hardly enjoyable. Just kept swinging my greatsword at the enemies who were focusing their efforts on Farkas.
The first time I completed this I was only level 14 and used a greatsword most of the time until the end of the game hit me by surprise. So my intention this time round is to explore more and do side quests and take the magician route rather than brute force with heavy armour and greatsword.
However it appears I'm still heavily dependent on the sword and armour and longbow as the magic is weak in comparison against this legendary difficulty.
In short, any tips/advice for a better experience in terms of a 50/50 split between companion and I when enemies engage and tips on magic as my fire, frost and shout are pretty much useless.
Also in the above mentioned level, some skeleton enemies would go down in say 6 hits of the greatsword and others would take like 50 before going down. Is this a glitch?! The two skeletons I'm on about...far from the difference between a mud crab and a dragon.
Thanks!
Thanks!
i will go back for him when im a bit stronger and with better gear
