Skyrim Upscaler - DLSS FSR2 XeSS has been released via Nexus!
Caporegime
8 Sep 2006
On Ocuk
DLSS/FSR2/XeSS don't work with ENB, but you can still use DLAA with ENB since there's no upscaling.
A workaround version with ENB compatiblity is in development, and Boris also said he would do compatiblity from his side, when he does this version will be compatible with ENB.
NOTE That they are two different things, ENB got issue with DRS, that's why it doesn't work with this mod, I made a workaround on my own using a completely different method that's hacky but works. When Boris decides to made compatibility for DRS, this mod will just work without needing any change.
Non-RTX cards can't use DLSS/DLAA, but you can use FSR2 and XeSS.
But since both FSR2 and XeSS has no official DX11 implementation released, I was forced to make a DX11/DX12 hybrid solution, so your card must at least support DX12 to use FSR2 and XeSS
It supports VR, but there's little gains with this mod due to the wasted performance for processing the whole VR texture when lots of the pixels are emtpy or unseen.
Currently a VR version is being developed that has fixed foveated DLSS and other optimization specifically for VR.
Performance gain depends on how much you are GPU limited, if you don't see any gains it's very normal, you are most likely CPU limited.
Even if you can't get more FPS in a CPU limited case, you are however getting the superior AA from the DLSS pipeline, it's much better than TAA, or you can just use DLAA (with performance cost).
DLAA/ENB user here with my impressions and a question...
Was previously running 4k downscaled by 35%. With DLAA at 1080, the improvement in clarity is just mind blowing. Especially considering I'm now also getting a bump of 10-15 FPS. For the first time ever, particle lights are no longer a factor with my framerate. Gamechanger.
Gained like an extra 50fps by using DLSS ultra performance
Was looking forward to trying this (especially for Skyrim VR) but seeing it doesn't work with ENB yet is disappointing as my mods are based around ENB really. Will have to wait a bit more....
DLAA works with ENB, but no DLSS as of yet... But it's coming :)
2070 super with a 5800x3d getting 30fps most of the time, hopefully this will help but i 100% still need my EMB lol
UPDATE : SkyrimUpscalerENBTestBuild05
You can download the test build here, newest versions not yet available (Patreon)
Creation Engine was perfectly adequate for purpose.
...when it was released 11 years ago.
Still using it in Fallout 76 after installing multilayer with crowbar and a mallet.... not so much.
Creation Engine was forked off from Gamebyro and still used components of its core engine lol, from Morrowind days! :D
I do hope Creation Engine 2 is brought right up to date.
Random question; I have a version of Skyrim that is modded to the hilt and I love playing it - however, since I switched from 3080 to 6800XT I get CTD.
What's the most likely culprit? Hopefully all the mods are GPU agnostic!
Delete both Skyrim and Skyrimprefs INI (BACK THEM UP) and reload the Skyrim Launcher. Also look in any of the INI of the mods and see if it's still detecting NVidia such as ENB's
