Sleaving of a pump
4 Oct 2005
Herefordshire
Hey guys not sure where to put this post.
I am going to buy a new pump/res combo and was wandering if there is a place that can sleave it, the last time I sleaved my previous pump, it was nto that good.
Is there any companies that can do this, does overclockers offer this service, when you buy the tech labs kit ?
I'd just do it yourself mate, it is one of the easiest things to sleave, and will only cost about 2 quid. There are plenty of online videos to follow, when it comes to the connector and pin just make a detailed drawing of where they come and go out of, or better still take a picture.
Depending on your pump you will either have a molex or 3 pin fan connector, and sometimes both, the 3 pin being for the tacho signal, just pop the pins out sleave, and pop back in.
It really is super simple to do. Just pop the pins out of the connector and away you go. You can do it with a toothpick, you don't need any special tools as long as its one of the usual 3/4 pin connectors.
I think I used 3/4mm sleeving and 2mm (when shrunk) for the shrinkwrap. What colour are you after? If its red I might have some spare lying around that I could just pop in a letter and send you for free.
Ill try to remember when i get up to see if i have some left and ill update this post.
UPDATE: Sorry dude, Looks like I used the last of it :(. Happy to give you any advice if you decide to do it yourself though.
