- 23 Aug 2005
- UK
I need a bit of advice.
This January my old 500W PSU was on its last legs, I decided it would be a good time to pick up the new-ish Corsair CX 750w Modular PSU. For a while everything seemed fine.
However over the last 2 months I've noticed that when I try to turn my PC from standby or completely off, the fans will spin but the LEDs in my keyboard/mouse wont light up, then the computer shuts back off. When I try turning it on again it will do the same thing until I unplug everything and wait a few minutes.
At first I just dismissed it as a loose connection, since I'd unplug my PC, fiddle with the cables and it would work again. However I've gone over my setup from top to bottom, and there are no loose connections.
I also upgraded to a 7950 a month after I bought the PSU, however I doubt that could be causing any issues!
Since this is sort of a random issue I'm unable to repeat it, does anyone have any ideas what might be causing this?
