Sleeping PC - Turn off fans
  • Thread starter Thread starter Deleted member 70857
  • Start date Start date
My motherboard is an Asrock ALiveDual-eSATAII board. I dont think it is very well known but anyways.
In my system there are a lot of 120mm fans, 6 infact not includeing the CPU fan.
When i sleep my computer i want it to turn off all the noisey fans except for obviously the CPU fan.
i do have a fan controller it is the Zalman ZM-MFC1
This has options to increse or decrease voltage to the fans (slowing them down or speeding them up) But no option to turn off all the fans.
Any help would be appreciated.
Im using WinXP Pro
When you put your PC into sleep (S3 Sleep) all your fans should turn off and stay off including the CPU fan. Only power should be going to the memory.
You must plug your fans directly into the motherboard to do this, I don't think it is possible with the fan controller, but i could be wrong.
ive looked around so much in my bios and cant see the S3 option ive even searched for it in the manual and come up with nothing
yeah i have that. then i can select to have it "disabled or auto" ive done botrh but everythin is still pretty much on
Mine does pretty similar.
I can't remember the exact settings in my BIOS, but for me, sleep mode has never worked in Vista, but I used to use it in XP no problem.
If I leave my bios set to auto, the machine turns off for less than a second, and then turns back on again.
If I set my bios to, sorry to be so vague I'm not at that machine right now, but S1 or S3, the machine will go to sleep, but my chassis fans keep going.
I've never got it to work since going to Vista x64, but seeing as it did work in XP, I can't see why not.
It's just something that I've had to live with!
Vin.
S3 Suspend-to-RAM sleep switches all fans off, including chassis fans. When in S3 sleep the computer appears off, the only thing left powered up is the RAM:
http://articles.techrepublic.com.com/5100-10878_11-6185330.html?part=rss&tag=feed&subj=tr
When I first tried setting it up in Vista mine would shut down only the display, everything else including HDDs would stay on. It turned out that I had enabled 'high availablility away mode'. Make sure this is disabled (it's under the 'multimedia' options in the advanced power settings list).
S3 now works like a charm for me, the computer appears completely shut down, but a click of the mouse button or push of the power switch and it wakes up and is ready to use in only a few seconds :)
Awesome, what a legend. Never used sleep before but I think I might from now on. Amazing fast sleep/turn on. Love it :D
I also noticed if hybrid sleep is enabled it does keep fans on as well. I turn it off and problem is fixed! :)
OK, I've been having a bit of a play around with this again this morning, as it's something I'd love to have working, and I've not tried it for about a year.
As I said previously, for whatever reason, this used to work with XP on this same machine, but has never worked on Vista.
First, I just tried sleep mode again.
It shut down the power, and then immediately started back up again.
I restarted windows, visited the BIOS, and manually set to S3, out of these options.
Back to Vista, tried sleep, same thing happened.
So, I figured I'd try hibernate mode. Better than nothing.
I'd disabled this ages ago, so popped back to the command prompt, and enabled it using the powercfg /hibernate on command.
Tried Hibernate.
The system closed down, except for the fans.
The chassis fans, and the CPU fan were still spinning.
I also couldn't wake it up. I had to press the power button to wake it up again, at which point it went through the post again, and windows complained that it hadn't shut down properly. I rebooted windows, and disabled hibernate mode again.
I've looked at the advanced power options, and everything seems to be set to power savings mode.
I don't seem to have "high availability away mode" but I do have it set to the following.
I just had a look through the device manager, at human interface devices, and the allow device to wake computer is disabled on all those that have the option.
So I'm pretty stumped.
Back to having to use full shut down and reboot.
It's a shame, I'd love to use sleep mode sometimes, but for whatever reason, I just can't get it to work.
The Mobo I'm using is an Asus P5B, with the latest (2001) BIOS.
Vin.
EDIT: Anybody tried this?
http://slicksolutions.eu/mst.shtml
I may give it a download and try it later.
EDIT2: Didn't work for me. Selected sleep mode, it said it configured the system, tried it, and it started immediately after going to sleep again.
After seeing this post I decided to give S3 sleep a go. Last time I ever do that on this build . . . .
I had the same problems as you, all the fans stayed on despite them being connected to the mobo, and the graphics card fan then span upto full tilt (Noisy bugger). Not only that, but when i pressed a button to get it to wake up, it wouldnt. I tried everything, powering off etc, and it never started back up. Wouldnt even POST. So I had to reset my CMOS. Needless to say, now disabled.
Yep, that's what I meant. I couldn't remember the exact dialogue in there :o
As for the problems entering/waking from S3 mode, maybe some of your drivers/devices aren't 100% ACPI compliant?
I guess that must be it.
As I said, it worked in this rig under XP.
No idea which device it is though.
The Nvidia ones change regularly, maybe it's the carppy Creative X-Fi ones?
Anyway, I tried a year ago, I tried today, maybe I'll just give up until Windows 7 ;) It's not the end of the world, the system is running great apart from that, it's just something that would be nice to have, not essential.
Vin.
You need S3 (Suspend to ram), S3 on its own wont make everything shut off and go into hybrid sleep, like I said in my last post
I had the same problem as you to begin with, the screen would turn off then turn back on again. After changing the power option to allow the computer to sleep it worked fine, except for whatever reason, the fan on my graphics card (Vortexx Neo with fan mate) will then be stuck at the lowest speed and won't speed up? So if before sleep it's 100%, after it'll be minimum, 50%? I can change the dial as much as I like and it won't speed up. Very confused about that.
Edit: seems to be a fan mate problem. Sent it to sleep took it off the fan mate, pluged it direct into mobo and turn back on, came on at full speed. I also think the Fan mate was causing power drop as it sounds slightly louder (I.e. Faster) when connected to the motherboard directly.
