I think if it is noisy at just 40% fan speed, then the card really must has crap cooler I thinkI think the gtx460 fan speed is set to a minimum of 40% so you will not be able to lower it below that. I have the same problem with mine and it is incredibly annoying. Tried to use afterburner to lower it with no luck.
