I'e got 2 Evga 980ti cards in SLI in a ThermalTake Core X9 case. I'm a bit concerned that the idle temp for both cards are in the high 60's.
The case got two 200mm fans at the front as intake at full speed.
Two 140mm fans at the back as exhaust running at a quiet fan curve. I've tried them at full speed, makes no difference to the gpu's.
Also two 140mm fans in my Corsair H115i in the roof as exhaust running on a quiet curve.
During gaming the GPU's go up to high 80's.
I've not touched the fan speeds on the cards. Nothing in the PC is overclocked.
Should I be concerned or is this normal? Think I need a couple more fans blowing air down on the GPU's?
Here are a couple of pictures of the setup.
