SLI advice
I'd reccomend trying to put the money towards a newer single card if possible - quite a few games lately have been pushing over 1GB of VRAM useage if you like turning the settings up.
Cheers guys, on the single card side would you guys have any recommendations that are not going to break the bank I am thinking around the £250-300 mark but if there is something exceptional I might be willing to go higher?
Any more opinions greatly appreciated .
cheers will that card run on my system?
Specifications:
• 4.70GHz
• Intel® 2nd Generation Core™ i5-2500K Processor
• MSI GeForce GTX 560Ti Twin Frozr II OC 1024MB GDDR5 PCI-Express Graphics Card
• 8GB Mushkin (2x4GB) DDR3 1600MHz 9-9-9-24 Blackline - 996776
• Kingston 64GB SSDNow V100 2.5" SATA-II Solid State Hard Drive
• 1TB Samsung HD103SJ Spinpoint F3 SATA-II 3.5" Hard Drive
• MSI P67A-GD65 Intel P67 (REV B3) Socket 1155 DDR3 PCI-Express Motherboard
• 680W Be Quiet! Straight Power CM BQT E8 ATX2.3 Power Supply
• Coolermaster CM 690 II Advanced Pure Black Gaming Midi Tower Case
• Arianet ECO II 120 Water-Cooling CPU Cooler w/ 1x 120mm Be Quiet! Silent Wings USC Fan
• NZXT Professional Braided Cables
• Sony 24x DVD/RW
• Arctic Silver 5 Thermal Compound
• 1 Years RTB Warranty
• Pre-Installed Microsoft Windows 7 Home Premium 64-Bit
Features:
• 4.70GHz Four Thread CPU
• Intel® P67 Chipset
• 8GB 1600MHz Dual Channel DDR3
• 64GB SATA II Solid State Drive
• 1000GB SATA II Hard Drive
• DirectX 11 via the installed GeForce GTX 560
• Video Outputs: 2x DVI-I, 1x Mini-HDMI
• 1024MB GDDR5 GPU Memory
• DirectCompute 5.0 and OpenCL support
• Dual-link HDCP capable
• OpenGL 4.1 support
• NVIDIA CUDA technology with CUDA C/C++
• NVIDIA Unified Architecture
• NVIDIA 3D Vision Surround ready
• NVIDIA SLI ready
• NVIDIA PhysX Technology
• 4x USB 3.0 Ports
• 10x USB 2.0 Ports
• 4x SATA III Ports
• 4x SATA II Ports
• 2x IEEE 1394 Fire
• Gigabit LAN
• High Definition 8 Channel Audio CODEC
• Expansion slots: 2x PCIe 2.0 x16 Slot (dual x8/x8), 3x PCIe x1 Slot & 2x PCI Slot
i notice it only has 2 X 6pin power connectors for the graphics card, would one of these NO COMPETITOR LINKING! do the job?
Apologies, but I could still do with an update to the above question, would the hd7970 card run on my machine, as to the link my pc only has 6pin would a 6-8pin converter work ok?
Any help would be greatly appreciated
Thanks
