SLI Bridge
16 Jun 2009
Hi,
Sorry if this thread has come up a few times before.
I have just purchased another GTX 760 and I plan on SLI'ing for the first time. I need to purchase a bridge.
Is this what I need, or will a very old bridge (that came with an asus motherboard) do the trick?
Basically are there any differences in bridges other than the look of them?
Thanks in advance.
The one supplied with the motherboard will be fine. The new HB bridges only make a difference with new series of GPU's 1070/80/TXP.
Similarly you could get an EVGA pro V2 bridge if you are running high refresh or high resolution (4k), as it makes a slight difference.
Other than that if your running standard 60hz and 1080p/1440p resolution the ridgid one included with the motherboard will be fine.
