SLI connector
31 Mar 2006
The SLI bridge connector which goes accross the top of the 2 cards I am using 2 7900gs and a DFI amd MB but I lost the bridge so will a bridge from a Abit SLI
or must you use the one which comes with the motherboard
or is it just as long as the graphic cards are the same then the SLI bridge will be the same as it connects to the Gcards together and not the MB.
Cheers D
As long as the connector is the correct size, or even better flexible it'll work.
Jokester
Edit: Edited your sig down to four lines to comply with the sig rules.
