SLI for the first time
Permabanned
28 Mar 2010
Never sli'd before so do i have to install drivers for each card? Currently running windows 7 so i don't know if it installs it automatically.
no, if you already have one card installed it will recognise the 2nd one when you put it in... or if you are putting both in at the same time then when you install the drivers it will recognise both cards
Once you have both cards installed into the system. When you boot into windows and login etc, a message will pop up in the bottom right corner saying, "sli capable system detected". Click here which will take you to the sli configuration menu of the nvidia control panel. Select sli and leave physx set to auto.
