Sounds about right.
With SLI you can't expect to get a 100% performance increase - 57% isn't too bad and in many games you will find it is even better (though in others it won't even be that much).
As for card placement, the ones you have pointed to are the x16 slots. If you put the second card in any of the other slots they you would expect a slight performance drop.
Are you running the latest version of the Nvidia display drivers?
