SLI GFX Card compatability
13 Feb 2006
Newbury
How do you know if different cards are compatible for sli, i always thought it was just the gpu that had to be the same but i am obviously wrong as ive got a 6800 and 6800xt, they dont work.
When i buy another 6800 how do i know it will work with or the other?
Thanks guys
6800 and 6800XT are not the same core though.
By same core that means they both need to have the same number of pixel pipelines and number of vertex shaders.
The cards also need to have the same type and amount of RAM.
i posted this in another thread
nVidia Forceware Website said:
Introducing ForceWare Release 80 Graphics Driver for SLI—
New Features:
Output SLI to your TV - using standard definition televisions up to 480i
Output SLI to your HDTV - using high definition televisions up to 1080i
New Flexibility:
Mix and Match Graphics Cards from Different Manufacturers
Example: You can use a GeForce 7800 GTX from manufacturer ABC with a GeForce 7800 GTX from manufacturer XYZ.
Note: You must still use two graphics cards that have the same GPU. For example, a GeForce 7800 GT must be matched with another GeForce 7800 GT (not with a GeForce 7800 GTX or a GeForce 6800 Ultra).
Mix and Match Graphics Cards with Different Input/Output Ports
Example: You can use a GeForce 6800 GT with Dual DVI & TV-out with a GeForce 6800 GT with Dual DVI & VIVO.
Mix and Match Graphics Cards with Different Clock Speeds
Example: You can use a higher clocked GeForce 6600 GT 550/525 with a standard clock GeForce 6600 GT 500/500.
Mix and Match Graphics Cards with Different Memory Sizes
Example: Using Coolbits, you can use a 128MB GeForce 6800 GT with a 256MB GeForce 6800 GT.
Note: NVIDIA recommends that SLI customers, whenever possible, purchase graphics cards with matching memory sizes. When dissimilar memory sizes are enabled to work together using Coolbits (value set to 18), the effective memory size for each card becomes the smaller of the two memory sizes.
