SLI GTX275
2 Jan 2007
England
Thinking about SLI'ing my GTX275 for BF3 - Power Draw Question:
Would my PSU cut it? It's this one here:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-009-ZA&tool=3
I was thinking not, but at £40-50 for GTX275 off the MM I might go for it. Failing that I should sell it and put the money towards a <blank>?
Cheers Guys!
EDIT - Rest of my Spec might help
Zalman ZM600HP PSU
MSI Neo2-FR P35 Mobo (Yes I know its not SLI Supported but was thinking of trying the patch)
e6300 @ 3.33Ghz
4GB DDR2 @ 950mhz
GTX275 896Mb
So instead of shelling out £70 for the PSU and £50 for another card (£120) I should keep my PSU and sell my GTX275 and buy a GTX460/GTX560Ti maybe? or what do you suggest?
I would definitley agree with that. 600W is enough for pretty much any single-GPU single card, and you're not at risk from the whole micro stuttering issue that's sweeping the SLI/CF crowd.
That said I don't actually know how 2x275s rank vs the card you've suggested... But if the benchmarks are about the same, then deffo single card option :)
I had 2 280's running fine on a seasonic 600w, so I would say 550 pushing but prob ok - 600 + your laughing (if its a quality PSU)
Think about the future though, a 750w corsair with the mega warranty could cover you for the next 5 years?
I thought GTX460's were DX11 cards?! Anyway I'm trying to get a GTX570 now...if my offer is accepted:-)
Was referring to the original idea of SLIing 200 series cards.
As an aside I went from heavily overclocked GTX260 SLI setup to a single GTX470 at first and while the 200 series SLI setup was slightly faster on paper I found the 470 smoother due to more consistant framerates (not microstutter).
