SLI help - GTX460
31 Dec 2002
on my PC
Hi,
I have an GTX460 can i sli it with anything or does it have to be in the GTX range?
Thanks for the help
You can use different cards, but they have to be the same model and memory to work in SLI. If they are just different speed, they will get clocked to the slowest cards speed.
What a lot of people do is stick older cards in to just process PhysX.
