SLi help!
14 Mar 2009
Ive recently purchased 2 9800 GTX's
Ive got them all set up etc and there working great
But when i come to playing games i get a green line on the left hand side of my screen
Any help?!
http://img152.imageshack.us/img152/9393/sli.jpg
Thanks
That's an SLI isage indicator overlay, to show you how much of the SLI setup is being used at the time.
sleeve84028 said:
Top section next to file and view should be 3d settings or somthing along those lines.
Roll over that pull down and then click "SLi performance indicator."
i have a problem with my new sli setup to when i play crysis warhead and an enemy shoots me the bottom half of the screen flickers, any clues?
try altering how SLi renders the scenes, under 3d settings options you shoudl have a drop down list of "nvidia recomended", "Split frame", "Aternate frame".
Try alternate frame rendering
cool thanks i will try that when i get home from work
edit: that did the trick :)
