Sli help
7 Aug 2013
Hey all. I was going to buy a second KFA2 gtx 780 from overclockers over the weekend to set up sli in my Ultima Extreme Envy but could not find the same model anywhere on the website, The nearest I could find was the HOF model.
So i was wondering if Overclockers were planning to stock more (very soon) ? or can i use the HOF model for Sli with my standard KFA2 780 ?
My PC knowledge is not as good as you guys so any advice on setting up my Sli would be great
p.s. This is the model im using http://www.kfa2.com/GTX780.shtml
Yep, any 780 will work and SLI will work independently, regardless of what the clocks are. You can have one at 1200mhz and one at 1100Mhz if you wished.
