I've only tried a few games with SLI and I've noticed that when using SLI, in order to make it feel smooth, you need a much higher frame rate than you would need with just one card.
E.g 1. The division with one card running at roughly 30 FPS felt fine to play.
With SLI running in the 40s FPS (also not scaling very well) it felt really stuttery and wasn't really playable. It wasn't until I'd reduced the settings enough to get a constant 60 FPS that it felt smooth to play.
2. The Witcher 3: With SLI getting 50 FPS it doesn't feel good at all. Yet as soon as I get the settings down a bit and it's running at 60 FPS constantly it's playing completely smooth and flawless.
Normally with 1 GPU I can play at 30-45 FPS and not have any problem whereas with multiple GPUs anything below 60 feels crap.
I was playing the Witcher with the frame limit set to 60 (60 Hz monitor) and adaptive v-sync on. I tried turning v-sync completely off but I still got the same result.
Using "smooth v-sync" in the nvidia control panel does help with this but it lowers the frame rate so much that you might as well be on one card.
Is this something that other people find with multi GPU set-ups?
Does it happen with higher refesh rate montiors?
If so then I'm glad I only have a 60Hz one.
60fps with 3 GPUs looks pretty smooth but the delay in input is pretty nasty. I'm not sure how people can play at 60fps with 4 GPUs as it must be even worse! I guess it makes sense when you think about how AFR works...
