sli or crossfire
5 Oct 2004
yo m8..just put 2 cards in my pc aint got sli lead,do i need 2 leads and can i buy them here(cant find them under cables)bit confused what sli and crossfire do which is best.....cheers mike
SLI then - what motherboard do you have? not all support SLI (officially) - you can run SLI in bridgeless mode - but for best performance you should get an SLI bridge.
Does seem Ocuk don't sell them, It might worth looking on that auction website.
What motherboard are you using :)
That board is crossfire only!
Edit: perhaps with a bit of jiggery and pokery SLI may work! :eek::p
If I were you, I'd sell one of your ultras, as you made it clear in your op that you don't know the difference between SLi and Crossfire, I would rate your chances of getting SLi working even half properly on that board to be slim to none. :)
