Depends on what res you're running. But I'd go for the single card solution as it has more memory, you'll have less heat and it costs less. SLI is only useful for larger monitors over 24", and it's pretty pointless doing it on two 320 MB cards as your overall memory would still be 320...
Plus whatever you're playing has to support SLI otherwise you'll just be using one of the two cards. Expensive heater for your case.
From personal experience, SLI is a bit of a waste of time.
Thanks guys.
My 320 8800GTS arrived today. The 640 would have been nice but out of my budget at the moment. Expensive stuff this PC gaming.![]()
