Hi Chaps,
I'm planning my new build. I can either go single GPU or go for SLI. I'm going to use 8800GT cards. My monitor currently has resolution of 1280 x 1024 maximum.
Is it worth going for a SLI setup as it will cost roughly the same as the single GPU but without the second card? I'm thinking about adding another card in the future when I can afford it. I'm thinking about this for future proof reasons and that i won't be able to afford to do another big upgrade for a year or two.
I've looked at the frame rates from some of the bench marking posted on here and there is a increase in some games with SLI setup. I'm also thinking that as new games come out which are going to use more GPU then maybe 2 cards would be better.
Any advice would be appreciated as i really want to put my order in and get the pc as soon as possible but i'm really stuck on this one.
if you find 25fps in crysis playable then all well and good - personally it feels clumsy and unresponsive.
