- 29 Oct 2012
- Skipton, UK
Hi
I have two Zotac GTX970 cards in SLI
They both have 2 6 pin power connections.
I run these from a corsair cx750m.
I have 2 pci power cables, each goes from 1 6pin at the psu and has two 6pin connectors inline / in sequence.
Now my question is;
should I have each rail for each card - using both of the 6 pin outputs on one card?
OR
should I run each rail to run both cards - using one of the 6pin outputs on the bottom card (as that's first from my psu) and then the 2nd inline / in series 6 pin connector to the second card.
I have run the cards both ways and I can't tell the difference.
I haven't yet managed to game using the second option so they haven't had chance to draw much power in that configuration.
I've never SLI'd before and not sure if these power connection differences matter?
The reason for asking is that option two is far neater in my configuration.
Hope that makes sense
Dan
OPTION 1
OPTION 2
Now my question is;
OR
Dan
OPTION 1
OPTION 2
