Sli Power
28 Feb 2011
Norwich
Hello guys im considering getting another Inno3d 980ti hybrid because i like to waste money on shiny things
Will my XFX Pro 850W be enough for them?
Fine. Peak they'll use about 250 W each, and the CPU about 185 W. Just don't raise any voltages if there's a chance everything will hit 100% simultaneously. ;)
Which single card would you suggest the OP move to instead?
That is the OP's comment :)
As to if its worth it, if you want more frames then sure why not. Having said that I would imagine a single 980Ti for a 1440p 60hz panel if its the dell you have is doing pretty solid?
I would just keep what you as if you like me wants new shiny thing, you will want something from the next get anyways :p
