Hi all
Ive got Sli G/Cards im using the top card for output.
I have a option in bios to use the bottom card as output.
the question is
My top card is getting very hot 81 Deg the bottom card is 53 Deg
I think the bottom card is making the top card hot.
if i change the output round do you think the top card will coll down a little.
as im not sure how sli works does card 1 take most of the load ( ie get hotter)
any input would be great
the question is
