Sli Question
13 Dec 2009
Plymouth
I currently have a Pny Nvidia Geforce 9800gt 512mb graphics card and wanted to get another and go sli, my first question is would i need to get hold of a second card which is identicle to the one i have down to brand and everything or can i use any Nvidia Geforce 9800gt card and hook them both up in sli?
2nd question is what kind of performance increase would i see going from 1 to 2 9800gt's?
3rd question is is there any aftermarket coolers out there which perform better on the above mentioned card over stock cooler.
You will need a motherboard that is SLI capable - if your planning on using it with the board in your sig - the Asrock G41M-LE isn't capable of SLI.
You don't need to match the cards identically, brand, etc. doesn't matter but they do need to be the same model.
Performance increase would depend on the resolution - around 1.6 to 1.7x increases on average are common.
There used to be several good aftermarket coolers for G92 based cards like the Arctic Cooling accelero line but I can't see much in stock any more.
Oh Poo :mad:, Im planning on upgrading the board soon to a P5Q Deluxe or equivalent so will be able to then with that board am i correct..
SLI is only officially supported on the LGA775 platform on nForce boards (and the ultra expensive skulltrail setup) - unofficially its possible to get it working on intel LGA775 chipsets but theres no guarantee of it working.
Most nForce motherboards are quite frankly rubbish and even the good ones don't work that great with the Q6600.
This is the problem with the nforce boards, you need one if you want sli, unfortunately they were never great quad clockers. The p5q deluxe on the other hand is one of the best quad clocking boards available, but sadly no official sli support.
Ah ok so Im definatley not getting a Nvidia chipset board as i have heard so many stories about them and overclocking (stable), but one is needed for official sli support:( thats a bummer, So would i be best off once iv'e got my new mobo to run my current 9800gt on it's own.
When you say no official support for sli on non nvidia boards does that mean it won't work or does it just mean the performance will be poor, in comparison to using nvidia chipset board.
Theres an unofficial "patch" to enable it on certain intel LGA775 boards but it doesn't always work with all configurations - even 2 people with very similiar configs one person might get it to work and the other not.
Your going to be much better off with something like a 5850 than going sli as apparently the 8800's and GX2's suffered from a fair amount of micro-stutter. You can then keep the 8800 as a physX card, or sell it to reduce the expense of the 5850.
8800 SLI does not suffer from micro-stutter... the 9800GX2 has some issues but thats another story.
I agree that selling his current GPU and going for a 5770 or 5850 or something would make more sense tho as a move to SLI won't be easy with the current setup.
Thanks for your input everyone think im gonna have to do some more thinking as to wwhat im going to do by the looks of it.
can someone please explain what is physX? and what is the need for physX? and is it only available with nvidia cards?
PhysX is a system for running ingame physics - when they use PhysX to implement the physics - on the GPU rather than the CPU. The GPU is potentially a LOT faster to process these types of calculations.
Very few games implement physics through PhysX to such a level that its beyond the capabilities of a CPU anyhow so at the moment it doesn't make much odds.
