sli question
10 Jan 2009
if you have 2 cards , is it possible to use the 3 way sli bridge or do you have to use a 2 way one , sorry for the noob question :rolleyes:
Im not sure if you can but when you order a card you always the the sli bridge anway so im sure you will get 1 i the box. Or is it a case the cardss are so far apart you need a longer 1 ? just asking as if thats the case then it helps answer future questions if anyone els answers :).
The sli bridges dont come with the cards, theyre supplied along with the motherboard. As each mobo manufacturers pcie slot spacing is different, they manufacture the bridge chips to suit their particular boards.
