SLI question
16 Nov 2009
inside your mind
hi there, can sombody tell me if you can SLI with a 8800GT 512mb and a bfg overclocked 8800GTS 512mb?
thanks!
Hey,
Im sure someone will correct me if I'm wrong but ass far as SLi goes I think its a no no, but you could use the second card as a PhysX card I believe.
No...
Slightly longer answer... while the nVidia drivers won't let you do it out the box as both are based on the same core it is possible to flash one of them with an edited BIOS and get it to work but because of the mis-matched specifications and that the drivers were never intended for this configuration you will get some issues including nasty micro-stuttering so the longer answer is still No even tho its theoretically possible.
