I have noticed (as anyone can imagine) that in every SLI configuration one card is the MASTER and the other(s) is (are) the slave(s) synched with the master.
Since I'm a natural born hacker and tester, I wonder: without moving the cards is it possible to switch the role via some utility or registry tweak?
That could be very interesting to try.
The master is the hottest (10 or more degrees) of the 2 (in my case) cards.
That's not because of position or air flow, infact if I disable SLI the 2 cards have the same temps.
I wonder, if such a thing is possible, setting the second as master, if the hottest one would become the second one.. It should.
That could be an advantage for many people since the second card is the fartest from the main CPU and easy to cool down.
