- 7 Jan 2009
Is it true that you cannot SLI a graphics card with the same GPUs but diffrent memory size on the cards?
For example...
Card 1 - GTX 460 768Mb
Card 2 - GTX 460 1GB
I was planning to SLI,but cannot fit another regular GTX 460 in my case due to where Gigabyte put the second Pci-e slot on my mobo,the only way id be able to SLI is if i had a really thin cooler GTX 460 like the up comming KFA2 GTX 460 which uses a slim cooler...
although i asked them and they dont currently have plans for a 768mb version...
For example...
