SLI scaling @7680x4320 in Shadow of Mordor.
Man of Honour
21 May 2012
Dalek flagship
I thought I would give this a run to see if the scaling had improved with newer drivers.
Settings used
Everything maxed
2160p with 200% resolution scaling (7680x4320 8K).
359.06 drivers
EVGA SC TX(s) @stock.
Single TitanX
4 TitanXs
VRAM usage.
SLI support has not been that good in games lately but with SoM the scaling seems to be spot on. Now if only there was a 8K G-Sync monitor on the market......
That is some nice scaling right there! If most games were like that and SLI was without its issues id invest in SLI quite easily!
Nice post btw
I love my SLI setup, it works far more often than not as expected.
But my single biggest frustration with it has been Bethesda games like Mass Effect and Skyrim, which make no use of a second GPU whatsoever including the very latest from them Fallout 4, even on a single 970, frame rates plummet rapidly once you go past 1440p resolution with all the settings at max.
..they really need to move on to a better Gfx engine.
I have to run high textures at 4k even with 8GB otherwise it can exceed it and cause crashing. Titan x is the card that can possibly max it out.
Cheers kaap, you've reminded me the game allows down sampling, so I'm going to see how high I can get
