Having problems
System spec
MSI-GD65 B3, 8meg ram, SSD and 1tb raid, 2 x GTX 580 all watercooled and temps show thats working fine, flow etc. Cougar GX 1050 PSU
Right then
All of a sudden SLI has stopped working, at first i though it was GPU that had died so i removed the bridge and power to each card and both work fine on there own. I have removed NVIDEA drivers a couple of times and used the clean install and all is well there.
Now if if put back in the bridge and connect the HDMI cable in the original GPU nothing happens. System appears to boot but blank scree. If i reboot and put the HDMI lead in the second card all is well, but the enable SLI mode is not available in the nvidea control panel.
Any ideas, its driving me mad ?
System spec
Right then
