Hi all,
A mate of mine recently decided he no longer needs to have a super dooper gfx card in his pc because he is into the Xbox 360 so much. So he lent me his gfx card which happens to be the exact same one as me.
Now im wondering if its a good idea to SLI my system with it because of the size of the card. Click the link below to see what i mean.
http://www.starks-place.co.uk/galle...00 GTX in SLI&pic=Leadtek 7800 GTX in SLI.jpg
However boldly going ahead without the slightest care to a burnt GTX card, i went and installed it in my system and enabled it in Windows. I then ran a 3D Mark 05 and got a score of 8800ish, which is actually less than when i have just one card in (around 8900) I also played some Oblivion and that didnt seem to be any better either.
So firstly, what is up with the performance? Is this normal? Do i need to have any special settings in Windows? See the other images in the above link for my settings.
My installed Nforce drivers i believe are v6.66. The GFX drivers are 81.95.
Anyway after about 30 mins of gaming the top GFX card (being the one with no air) reached 65 degrees C and the bottom was near 50. Is that bad?
Should i just unplug it as the SLI performance isnt going to get better? Or is it too hot anyway? Or is there a way for me to improve the performance if the temp is acceptable?
Thanks for any replies.
D.
D.
