Sli Ultra set up for 1200 quid?
14 Nov 2007
My friend would like me to build him system (case only) including twin ultras, any recomendations?
My own specs (built in Dec and no problems,touch wood and running Vista 32 bit at a happy 2.7ghz and cool (according to "core temp")
THESE ARE SPECS FOR MY PC BUILT IN DEC..
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB)
Arctic Cooling Freezer 7 Pro CPU Cooler
Abit IP35 Pro (Socket 775) PCI-Express DDR2 Motherboard
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2(1.9-2.0 Volts-CL 4-4-4-15)
Western Digital Caviar SE16 500GB SATA-II 16MB Cache
Pioneer DVR-112DBK 18x18 DVD±RW IDE Dual Layer ReWriter
EVGA GeForce 8800 GT 512MB Superclocked- GDDR3 HDTV/Dual DVI (PCI-Express) -
Lian-Li PC-7 PLUS II Aluminium Midi-Tower Case
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU
Would I 620 run 2 ultras and a quad? I dont think that it even has 4 connectors... I would think about an 800 or 1000w PSU maybe.... the EVGA that you have put in this quote is not a ultra... are they 8800 ultras or not?
Stelly
Sorry slight confusion.. the specs are MY pc built in dec.. I am asking for NEW specs that will include 2 ultras to the value of 1200 pounds . Thanks..
Don't bother with SLI Ultras if you have a budget of only £1200, get SLI 8800gtx instead. Saves £200 and isn't much slower.
I got a single GTX on a 24" monitor and everything apart from Crysis runs at max framerate. I would recommend getting a single GTX with mobo and getting another at a later date if you think you need it.
