As far as I know, you can only SLi on an NVidia chipset. So if you tell us your motherboard, or the motherboard in question, we should be able to tell you.
Hi no it wont as that has a AMD chipset on it, for SLI you need either the Asus M4N75TD or the M4N98TD, the 98td is the one i recommend which can be bought for £90.
So just to ask, was what I said before about needing an "Nvidia Chipset" correct, or is there more to it then that? Obviously 2 PCI-E slots extra, but disreguarding that? (I dislike not knowing simple things like this )
your 85%right, it needs to be a Nvidia chipset, but also needs to run both pci-e slots at the same speed, just because it says it has two 16XPCI-E slots doesnt mean they both run at the same speed with two GPU'S inserted.
