I've had a Dual BFG 7900 GT OC SLI setup in my pc for a while and everything ran fine. I got 2 of the same cards so there would be no problems with SLI, and SLI was perfectly simple to set up. I recently noticed a fault with one of the cards, and had to RMA it back to BFG tech. Sent it off on Tuesday afternoon and got the replacement this afternoon. Very speedy turnaround (less than 48 hours!) although it was left on the window ledge at the front of the house by the courier for the best part of 8 hours free for anybody to pick up! That's beside the point though. I opened up the box and found I had been sent a 7950GT OC to replace the 7900 GT OC. I was under the impression that the cards essentially needed to be almost identical for SLI to work, but the replacement card appears to have more memory and runs at a higher clock speed, and sure enough, I don't see an option to use SLI in the NVIDIA control panel.
Is there anyway I can get SLI to work in a healthy way with these 2 cards? Are there any tools I could use to underclock the new card or overclock the old one so that they have similar specs, or will I need to ship it back to get a 7900? I'm not even sure if BFG would even replace it with an older card now as I guess the 7900 is probably no longer produced. If so I guess the lifetime warranty is a bit crap when it comes to SLI, as you won't get a usable replacement just 12 months later!
These are the important specs to save anyone having to look:
BFG Technologies GeForce 7900 GT OC 256MB DDR3
Core Clock Speed: 475Mhz
Memory Clock: 1320MHz
BFG Technologies GeForce 7950 GT OC 512MB DDR3
Core Clock: 565MHz
Memory Clock: 1430MHz
If anyone has any suggestions, let me know! (that does not count suggesting buying a nice new 8800Ultra. I would do that if I had the cash
Core Clock: 565MHz
