SLI with different cards?
2 May 2011
Woking
Hi,
Just a quick, and very ignorant, question...can you run two different cards in SLI? I'm thinking about a GEFORE GTX 460 with a Gigabyte 460, which presumably are pretty much identical (different coolers I believe).
Just wanted to check before buying one...thanks in advance!
dirtychinchilla
Usually if you match the GPU then you are pretty much sorted for SLI.
However then GTX 460 is a bit trickier as there are two main versions (768MB and 1GB) which use slightly different GPUs which can't SLI with each other. There are also some 192bit memory versions floating about that also don't play nice with standard 256bit cards.
Therefore, may I ask wxactly what model number GTX 460 cards you are looking at? If you have access to any of the cards already then you can run GPU-Z to check the specs.
Id reccomend using the gigabyte card in the lower pcie slot, this way it wont be starved of airflow. Had two gigabytes like that on a second rig, had to ditch them due to very high temps due to the non reference coolers they used, this and very tight slot spacing on the motherboard.
