I have just re-configured my main rig for SLi running after using one of the cards in a different rig.
Now when ever I try to enable SLi, the nVidia control panel says 'Before you can enable SLi, all graphics cards must be installed in PCI Express slots with bandwidth of x4 or greater.
the main infor page says that the bus speed is set to x8, which if i remember correctly is correct as SLi halves the x16 of the PCI express.
Any ideas as to what may be causing this snag?
Have re-installed both motherboard and gfx card drivers and the problem still persists.
Cheers in advance
Paul
Cheers in advance
Paul
