- 6 Jul 2013
Hi folks, Hopefully someone can help/suggest something.
I recently aquired 2 new GTX 670 cards, to sit in a z87 deluxe mobo.
Install was fine, and off I went, happy with the performance as this was a quite a large step forward from my previous rig.
It was only recently, whilst playing around with lightboost, that I wanted to see what actual performance I was getting, and whilst the results werent bad, they just werent what I was expecting.
After a bit of testing, It seems that I am only using one of the 670 cards. Afterburner reports 1 cards usage varying, task dependant, whilst the other is constantly stuck at 30 or 31%, either on the desktop or in game. It doesnt move.
Running the Valley benchmark shows a similar story, showing clock speeds etc for one card being high, the other extremley low.
Having looked on Nvidia COntrol Panel, there are no options anywhere relating to SLI. I have tried numerous different driver versions, all with the same results.
I have tried both cards individually, and both work fine.
Both the cards are displayed without error in device manager, and both cards are displayed in the nvidia control panel, there is just no option to enable SLI. It appears at the moment, that one card is being dedicated to graphics, the other to physx. The only option I have is so change Physx to the CPU. This still only results in one card being assigned to graphics.
I have looked through my bios, but cannot see anything obvious relating to SLI being enabled/disabled.
The only piece of the puzzle I cannot test is the SLI bridge, as I dont have a replacement, though, I am under the impression SLI would work regardless of a bridge being present or not - just with very reduced performance.
I am at a complete loss as to where to turn.
Would greatly appreciate any help.
Thanks.
Thanks.
