Sli x8x8 vs x16x16 SLI
pci-e x8 = 2GB/s per stream, max bandwidth duplex 4GB/s
pci-e x16 = 4GB/s per stream, max bandwidth duplex 8GB/s
and i think an extra 10 watts
Depends... PCI-e @ x8 2.0 is perfectly fine for all GPUs currently available - tho I have my reservations when it comes to the 295GTX if you plan on going quad SLI.
PCI-e @ 8x 1.0 is fine for upto an overclocked 8800GT so prolly anything upto a 250GTS you wouldn't notice any performance difference... above that theres a bit of a drop off.
I'm interested in this, I have a p35 motherboard with an E8400 running at 4Ghz, its been a good build. I've recently started gaming at 5040x1050 through a TH2Go and although my GTX280 is running it ok, I have had to turn some things down.
I'd like to go to a better card, either the new 58xx or a GTX295 (if they drop in price as the game i play has a couple of ATI issues).
I believe the motherboard I have is PCI-E 1.1 16x (IP35Pro), does it have the bandwidth for running a better card?
I can go i7 but not sure I'm going to see 500 quids worth of improvement over a 4Ghz Dual Core. Granted I could get an SLI board and another GTX280 though which would still be a pretty cool setup.
Thanks for any help
Fred
I think the 295GTX does have the bridge chip onboard which does mean you don't quite take the same hit as running x8 1.0 on 2x 275GTX say would...
