Slidly KB
1 Mar 2007
Portsmouth
Ive got my KB on a wooden surface, but it often sides about too much around my desk. Anyone know off an fabric or some similar I can stick to the underside off the KB tabs that sit on the deak?
You can get a non-slip matting from Boyes designed for just this job. It is available in a variety of colours, and then just cut it to the shape and size you require
Duck make non slip matting. Great for under mouse mats, car dashboards etc. you can get it from Wilkinsons. Same as the rubber feet.
You can get rubber/cork round pads from any decent arts/crafts or DIY store!
My S510 already has rubber feet but the upper area height when flat is too flat so I raised it a few mm by buying a pack of rubber pads :
Got these from a shop called "The Range"
You live in Portsmouth so not so far from me, the shop is literally a few roads down - I can see if they still stock them if you like? alternatively I have the same height sticky pads in "cup" shape I can post to you?
This is what they look like on a tea coaster I improvised:
Both types cost 99p per pack.
I have a small pot of them cut into square bases (as above) so if you would like some let me know how many and where to post :)
We if you wouldn't mind posting some to me, I would be very grateful.
mail me your addy and I'll bung some in an envelope!
Remember to state how many :)
