Slient Advice
9 Dec 2006
@ManCave
So i'm going for slient as possible so i picked the Antec P280 Case which has done really well. i just not sure where to put the fans for silence?
They all get the Same Temps every way i try.
CPU Idle 27C Light Load 30C Full Game (BF3/Heaven) Load 45-50C
GPU Idle 27c Light Load 36c Full Game (BF3/Heaven/PS2) Load 45-50C
Ive tried (Fractal 120mm 19DB Fan @ 38CFM x2)
i instantly moved the back fan so The Heat goes one way. Making better flow.
2 Top No Intake
2 Intake no Top
1 & 2 Middle No Top/Intake
2 front no mid/top
Currently using 1 Front 1 Mid
Also Are them Silencing Kits worth it?
Anything i Could Get To make it quieter?
I have Found that the CPU Cooler as facing upwards does not need top fans to push hot air out:D
