Hi, I just purchased an Aoc G2460PG TN Gsync monitor, I tried a TN Predator monitor but the uniformity was awful and one side was a lot lighter than the other. This Aoc monitor is not perfect but none of these monitors are and after reading a lot about the new monitors, getting a perfect one without uniformity issues and back light bleed is pretty much the same as winning the lottery, this one seems like the best of the bad bunch for me but I just wondered if it is normal to get a lighter bleed in the same corner as the buttons for the OSD? it seems to be more of a blue patch than white even though the power light on the monitor is green. nd is really not noticeable at all unless on a completely black and still back ground, I don't think I'd be sending it back plus I don't think I could now as I have made the back light bleed less noticeable in this corner and other areas but cutting very tiny bits of an old store card up and wedging them deep under the bezel of the monitor.
Over all I am happy with this monitor compared to the Predator and after looking at the nightmarish screenshots of back light bleed mine looks pretty good.
