Slight n00b question...
14 Sep 2007
North Wales
Morning all,sat at work bored so have deicded tonight i shall dust off some bits i have an try and OC them
But....how can i boot up the PC without a case?MOBO i have is an A7N8X Deluxe. Hooked it all up few weeks back,but was puzzled at how to boot it up :D
cheers
Mart
Most use the screwdriver trick on the power connectors on motherboard; making a connection between the two metal prongs.
Have a look in the manual that came with the motherboard and it should show where all the front panel connectors are connected to.
