Slight problem with dell 2405FPW in portrait
30 Jan 2004
I've just put my monitor in portrait to make it a bit easier to read some newspaper articles, but have come across the slight problem that it seems to cut off the very right if the screen.
Now it wouldn't be too much of a problem but the scroll bar is cut off, and because I am using firefox the small close tab button is cut off when I have multiple tabs open. It's also just a bit annoying as there is also sometimes text there that I can't read.
Any one else had this problem, or suggest a way to fix it?
Just as an example of how much it cuts off, when you are viewing the forums it cuts off most of the 'Views' column on the right.
Cheers for any help.
