Hey guys, needing to do a slight re-build as my current Motherboard is starting to give up and the case I have just isn't ventilated enough.
What I'm looking for is a slight rebuild in which to overclock my PC to a decent level and what I really need for this is a new Mobo/Case/Ram combo. The main components I have at the moment which I will be keeping are as follows.
Corsair TX 650W PSU
Intel Q6600
Noctua NH U12 P Cooler
GTX 280
3xHDD's of various size.
2xDVD RW
On both the mobo and Ram speed I have atm I struggle to keep the Q6600 @ 3Ghz due to the slower speed of the ram.
So looking for a nice upgrade to get more out of my system and keep the temps nice and cool at the same time. I don't have the most extensive knowledge in terms of Motherboards so that is the main advice I require.
Also would consider a new HDD to replace 2 of my drives.
Looking to spend around £200 or just over.
Corsair TX 650W PSU
Intel Q6600
GTX 280
2xDVD RW
