My rig, as sig', is a year old now me thinks. At stock everything it runs perfectly. I am preparing to upgrade my CPU to a 9550 E0 and a 4870X2 but am concerned about a few issues I have with the current setup.
My overclocking days of this rig are long gone CPU wise as it doesn't play ball with anything greater then 10MHz!! I have recently been playing with the RAM 4Gb of OCZ 6400C5. I upped the FSB of my P35DQ6 to 300 and knocked the multiplier to 8 leaving the Q6600 at stock. The RAM score went from 5.7 to 5.9 (Vista HPx64) but failed after 2 days. Now the PC won't boot at all with an FSB of 300. I did set the PCiE bus to 100MHz.
I have played with various voltages and yet nothing. The bios constantly resets to stock 266 x 9. My question is simply this... Is it the CPU that is useless or do I have a dodgy mobo?
I would like to bin the mobo, the RAM and the CPU and go X48, but I cannot afford to replace everything. I would like to be able to game at 1680 x 1050, all high so I want to change the CPU and the graphics card but am worried I will be back to square one again.
Thanks
Thanks
