- 14 Apr 2014
- Hampshire
Tried all of those, and the same thing happens...............AAAAGGGGGGGGGGGGGHHHHHHHHHHHHHHHH
If you’ve done all of that it’s your PS5.
eloutput.com
I agree with this - try resetting the video settings and again check if there are any firmware updates for TV if not already done so. I’ve had to reset the video settings before and it helped.Could try resetting the video settings:
Safe mode on PS5: How to fix video and image problems
Run safe mode on your PS5 to fix video resolution issues that has left you with no image and a black screen.eloutput.com
The software for the PS5 is up to date, the firmware for the TV is up to date.... AAAAAGGGGGGGGGGGGGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH. I tried the native PS5 HDMI Cable into the TV, Minus the splitter into HDMI 2, the port that it is within and the PS5 screen shows like normal, then it does the same thing with the screen as the video provided shows. IT IS NOT THE PS5 that is at fault............ AAAAGGGGGGGHHHHHHHHHHHI agree with this - try resetting the video settings and again check if there are any firmware updates for TV if not already done so. I’ve had to reset the video settings before and it helped.
From the video, it looks like the TV loses signal from the HDMI connection.
Another day. More Confusion. Literally just used the PS5, the HDMI Cable that came with the PS5 like I said is connected into a HDMI Splitter, the HDMI Splitter is then in the 2nd HDMI Port on the TV, so HDMI 2. Just turned the PS5 on, and it came on, showing up with the launch screen on the TV, perfection, so ran a little test and managed to play a game on it, then of course it started to flicker again, like in the video - after some 10/15 minutes of gameplay. So could it be the PS5 HDMI Cable that is maybe faulty? After all I have had the PS5 for the best part of 2 to 3 years. If so which HDMI Cable should I look at getting?
I thought you'd already tried another HDMI Cable?So could it be the PS5 HDMI Cable that is maybe faulty? After all I have had the PS5 for the best part of 2 to 3 years. If so which HDMI Cable should I look at getting?
(Or at least that's what you said)So is it because of the existing PS5 HDMI Cable that I have, as to why it is not working?HDMI 2.1 cable plenty can be had cheaply. Don’t spend over £10. £6-£7 range will do.
I did yesterday - I tried a standard HDMI Cable.I thought you'd already tried another HDMI Cable?(Or at least that's what you said)
Personally looks more like a TV Issue with it displaying the TV's Sony splash screen, I'd like to see footage of it on a different TV to prove that it's still an issue on other TVs
Whatever "standard HDMI Cable" actually means?I did yesterday - I tried a standard HDMI Cable.
It’s just what we all go through to eliminate possibilities. A new cable may tell you nothing or it may tell you that the problem lies elsewhere or it might even work. Process of elimination. Cables can fail and there is no way to see or tell why that is. It just happens sometimes.So is it because of the existing PS5 HDMI Cable that I have, as to why it is not working?
If it works fine then its likely a device that is having issues with the HDCP handshake, most likely the splitter.Tried that yesterday, and again with a new HDMI Cable, a High Speed One, got 15 minutes out of it before it went odd again!!!! AGGGGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHDoesnt the PS5 have HDCP (high-bandwidth digital copyright protection) - Just checked it does. This can cause handshake issues...
Worth disabling it for troubleshooting (disabled certain streaming services such as netflix etc will not work as HDCP is somewhat designed to stop screen capture)
Shamelessly stolen from the web, in the PS5 menu do the following:
Test it with this disabled and see what happens
- Go to Settings and then click on System
- Choose HDMI to get a list of options
- Turn off HDCP by hitting the toggle next to Enable HDCP
You’ve got four possibilities with a bad handshake from PS5 to TV.
Faulty PS5
Faulty cable
Faulty TV
Faulty splitter
A 5th could be software which means a reset of both PS5 and TV.
