Slightly pedantic pointless question...
31 Mar 2006
Sydney Australia
but... Why do you all call the ground "the floor". From my perspective the floor has always been something that is enclosed by walls and is man made - i.e. you install flooring in a house. If it's dirt/grass/rock then it's "the ground"...
Am I wrong? (the answer is not yes unless you have a valid reason...)
I have never called ground "the floor". It's "the bottom floor" (if there's no underground), "the ground floor" etc., but never just "the floor" :\
In fact, I'm not sure I've heard anyone else call it "the floor".
wut? So you don't say "oops I dropped some lube on the floor" when doing naughty things in the bedroom?
Ok - so you're a little odd...
Yes, you’re just being pedantic. :p
Thanks. I did admit as much. :rolleyes::p
Good point!
For some reason I thought we were talking about the different floors of a building! :D
Tom is right, I am often found to be cursing the dropping of the anal lube bottle on to "the floor" rather than "the ground floor".
From Def 7 it could potentially be used to describe ground... still doesn't seem right to me.
Dictionary def:
floor
   /flɔr, floʊr/ Show Spelled[flawr, flohr] Show IPA
–noun
1.
that part of a room, hallway, or the like, that forms its lower enclosing surface and upon which one walks.
2.
a continuous, supporting surface extending horizontally throughout a building, having a number of rooms, apartments, or the like, and constituting one level or stage in the structure; story.
3.
a level, supporting surface in any structure: the elevator floor.
4.
one of two or more layers of material composing a floor: rough floor; finish floor.
5.
a platform or prepared level area for a particular use: a threshing floor.
6.
the bottom of any more or less hollow place: the floor of a tunnel.
7.
a more or less flat extent of surface: the floor of the ocean.
8.
the part of a legislative chamber, meeting room, etc., where the members sit, and from which they speak.
9.
the right of one member to speak from such a place in preference to other members: The senator from alaska has the floor.
10.
the area of a floor, as in a factory or retail store, where items are actually made or sold, as opposed to offices, supply areas, etc.: There are only two salesclerks on the floor.
11.
the main part of a stock or commodity exchange or the like, as distinguished from the galleries, platform, etc.
12.
the bottom, base, or minimum charged, demanded, or paid: The government avoided establishing a price or wage floor.
13.
Mining . an underlying stratum, as of ore, usually flat.
14.
Nautical .
a.
the bottom of a hull.
b.
any of a number of deep, transverse framing members at the bottom of a steel or iron hull, generally interrupted by and joined to any vertical keel or keelsons.
c.
the lowermost member of a frame in a wooden vessel.
It's simply a transferable term used as a figure of speech.
In my mind I don't believe that it is. I find it irritating similar to someone pronouncing performance as preformance or specific as pacific.
A floor is the lower interior surface of something, the ground is outside and not surrounded by walls - i.e. if you drop something on the pavement, it's the ground.
IMO anyway.
Don't get me started on this sort of thing. I heard someone yesterday talk about needing a new windowscreen in their car....................yeah, right, everyone should have a windowscreen to stop windows blowing in.............arrrrrghhhhhh......
IMO anyway.
Well, we have transferable correct terminology such as 'Ocean Floor' and 'Valley Floor' to dispute that. It is a transferable term, the vagaries of language aside, it depends somewhat on contextual usage.
It's correct to use the sentence "don't pick that up off the floor" as it is to say "don't pick that up off the ground" despite how it may annoy you personally.
The other terms you mention are mispronunciations of words and so are unrelated to words that have multiple correct definitions and/or common usage.
I personally refer to 'floor' commonly as the interior and 'ground' as the exterior, but it is a more a matter of choice than any specific correct usage.
They were merely examples of the incorrect use of the language that irritate me - not direct comparisons. I personally don't see "Don't pick that up off the floor" to be correct if you are outside.
Now if you are standing on the floor of a valley the patch of 'dirt' you're standing on is still the ground IMO. The Floor of the valley is a description for all of the ground making up the bottom of the valley.
