Hi all,
I'm changing motherboards, and just realised that the back plate of my Tuniq Tower is stuck to the old motherboard, making moving it across a bit difficult! I'd take this as an opportunity to get a slightly smaller, as in less tall, CPU cooler.
My case is the Coolermaster Stacker, which has fans in the side door. The Tuniq Tower is so tall I have to remove the fan enclosures in the door to fit it in, so I'm after something slightly lower (or even a lot lower).
The Tuniq Tower was generally great, kept my CPU cool and was silent, everything I want really! So I'm after a recommendation of something a little less tall, that's all. I see the other popular ones (Noctua, TRUE) seem to be the same size or even a little taller!
Thanks in advance guys!
Edit: as a second thought, is it possible to buy those brackets that stick onto the back of the motherboard, separately?
