I'm pondering with the idea of recycling some old bits into an HTPC and I quite fancy using a Silverstone LC13 as the case however it looks like the supporting bar runs right over the CPU socket.
Does anyone know if the bar is removeable or if you can get something as big as a Ninja underneath it?
EDIT: Scratch that for an idea, the Ninja is the same height as the case almost so there's no way it'll fit inside. Therefore I'm going to need a new HSF so looks like a low profile Zalman will be the way to go.
